Psyched! Almost here...
Got a call from my dealer - my 07 Crew Cab LTZ Z71 VortecMax should be in by next weekend - can't wait! Only problem will be figuring out how to get to the dealer 250 miles away without inconveniencing my family...
I'll post pics when I get it.
Vortecmax in a Z71?
Yep,Its how I ordered mine also (It should be built anyday now) You can get it as a seperate option or as part of the "NHT" Max Trailering Pkg.
Here's the explaination from an earlier post of mine,Hopefully its not to confusing........
On the '07 "GMT900" 1/2-ton trucks you can get the "VortecMax" 6-liter (RPO L76) two ways,Either as a seperate option on the crew-cabs and ext.cabs (short or standard length bed) or its comes as part of the "Max Trailering Package" (RPO NHT) available on crew-cabs and ext.cab (standard length bed only)
When you spec it out as a seperate option you get the "L76" 6-liter along with the "M70" 4L70E "Super-Duty" transmission and the 9.5" rear-end with 3.73 rear-end gears and you can still get the Z71 package or the Z60 suspension with 20" wheels.
When you spec out the "NHT" Max Trailering Pkg. it also comes with "L76" 6-liter,"M70" 4L70E transmission and the 9.5" rear-end,but it also includes the "G80" locking diff. w/4.10 gears in the 4x4 models (3.73 gears in 2wd models) it also comes with the autotrac transfer case on 4wd models,fog lamps,"Z82" trailering pkg.,"Z85" handling/trailering suspension,H.D. rear springs and a bigger front sway bar,This package increases towing capacity up to 10,500lbs.
17" wheels are the only wheel size available with the "NHT" Max Pkg.
You'll notice the biggest difference between the two is the fact that with the "NHT" pkg. it comes with 4.10 gears in 4wd models,this is where they get the 10,500lb. towing capacity,If you get the 6-liter as a seperate option you can only get 3.73 gears which is limited to an 8,500lb. towing capacity.
Also on the rear-end,If you get a crew-cab it will have rear disc brakes because stabilitrak is standard on all crew-cab models,however on ext-cab models drum brakes are std. unless you order the stabilitrak option seperately or the "NHT" pkg. which includes stabilitrak as part of the pkg.
Yea,we already pull our hair out now,Thats just one reason why we usually ask for the VIN when ordering parts,theres just too many build variences. :flag:
Could someone please tell me what "NHT" stands for, I have been seeing it used around here but for all my thinking I cannot come up with the words. I know what the Max Trailering package is, just not the letters.
"NHT" is the RPO,or "Regular Production Option" code,used by the dealer to order that package,Just like "Z71" is an RPO code used to order the Off-Road Suspension Package option or "G80" used to order the Locking Rear Differential.
RPO codes is also what allows us parts guys to order correct parts,we can look at the "SPID",or "Service Parts Identification Label" to determine what all options and standard equipment is on a GM vehicle.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
