Door ajar???
Rod Slinger
I Just got a 2003 Chevy 1500HD 4x4 Crew cab. After a couple of weeks driving, my left passager door ajar message was staying on and would not go off even when the door is closed. I changed out the latch assembly on the door thinking the sensor was out. This was not the problem. When the message is on The doors will not lock when it is up to 8MPH and the inside light will not go out unless I push the override switch. I tried to trace the wiring harness and see where it connects into the steering colom to see if there was bad wire but gave up. During this time I found that my steering wheel does not lock when truck ignition is off and key is out of ignition. Not sure if the steer has anything to do with door adjar? What can I do to alieve the problem with the adjar message and or steering.
Thanks
Anyone???
No, the steering wheels dont actually lock anymore. Does your message go off when you push the latch in? Open the door and push the latch back until it locks. If it still does it, you got me stumped.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
