8.1Lsupercharged in avalanche 1500
hey everyone my girl friends dad and i were talking and we want to take the whole drivetrain and motor out of his 03 avalanche and put in a crate 502 or 496 w/ a whipple supercharger and an allison tranny is this possible even though its a 1500. also will the allison withstand the power. i figure will need a custom tune to put everything together right haha. :sigh::cheers:
As far as I know, the Allison will not fit in the Avalanche without MAJOR structural modification.
other than that...Sure. You could buy a 3/4 Avy with the 8.1 in it and kits were sold to bolt a S/C right up to it...So it's entirely possible.
You can have almost any transmission built to handle high horsepower. Just got to throw $$$ at the right people and places.
because growing up he had a 1970? or 71 chevelle 454 ss. he likes displacement alot as you can see. now if it were me i would just buy a whole new truck vortec max and throw a supercharger on it thats me he just wants to have the crazyest thing anyone can find
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
