Got my 03 taillights!!
Well, just got my new 03 taillights this morning, and they do fit no problem. The only problem is that you do need to buy a new harness that runs from the distribution block by the spare tire to each individual side, since they have different sockets and 4 bulbs instead of 3, other than that it was a straight forward install.
Click on link in sig and go to HD updates, there are also a couple of pics of my 01 HD next to a 03 HD.
please post part numbers for the tails and wiring harnessess, and pictrues of the wiring harnesses from the distribution box if possible.  :thumbs:  :D  I am thinking of doing the same thing, but did not think the tails would be available yet. Also, what was the $$ damage if you don't mind me asking??
Thanks,
Kyle
Part numbers for the harness' are:
DS--- 1653 1401
PS--- 1653 1402
MarkD, if my buddy doesn't want my carbon fiber tails then they will probably end up on ebay(not sure yet).
I wonder if the 2003 Chevy lights will pop right in to a 2003 GMC??
If so, can I take those two part numbers and order thru a place like GMParts direct?
Thanks
Nice HD!!!
I'm sure that they'll fit a 03 GMC, but you'll need
P/N Lights
D/S---15766535
P/S---15766536
P/N Harness
D/S---16531401
P/S---16531402
I'm sure that you could order from GMparts, but the harness numbers aren't listed there yet.  Also, try P&G Chevrolet out of PA., they seem to have parts-o-plenty in stock.
Thanks for the reply. I'll find the number and give them a call Monday.
8100HD; your truck looks great! What are the specs? Compared to the blue 03, it looks like you have it lifted several inches.
 I bet you get complements all the time, and for good reason.
HDMax, truck is a LS loaded 8.1/allison, with UPD intake, descreened MAF, Superchips Micro tuner, The Other Guys Headers, 3" Performance Accessories body lift w/gap guards, 295/75-16 NITTO Terra Grapplers on 16x8 ARE Baja's, Escalade handles all around, Escalade cluster, Escalade mirrors, bumper covers and grill painted to match, Billet Specialties bowtie, Steelhorse lighted stepboards, Piaa headlights and back-up lights, GM bed cover, 03 taillights.
Inside is stock xcept for huskyliners and a full system.
Thanks for the compliments!!
Definately a very nice looking truck!!!
I finally found a dealer in this area that had '03s on the lot. Checked out the taillights and knew that I was going to be ordering a set for my '02 HD. Guess others have thought of this first :)
Tom
Great looking truck and add-ons.
Please post the part number info on the PIAA fog lights and back-up lights.
Thanks!!
Thanks for the comments Tom, BTW who did your headers, I ordered mine through your company last week and am looking for a reputable company to do the install, if I decide not to do it myself.
We can install your headers if you can't find any place to do it.
I tried to order some taillights and harnesses today. No problem getting the taillight but they didn't show a listing for the harnesses. GM didn't show these numbers.
Tom
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 588 Guests (See full list)
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
