2007 cold start engine noise
mattrudella
Hello I'm new to the forum and I own a 2007 Silverado (new body style) w/ LMG engine (DOD/flexfuel/iron block). I have a noise on cold start (temps below 20 degrees). The engine knocks for approximately 3 seconds or until the oil pressure reads ~40psi. The knocking noise sounds like engine parts without oil, 2 knocks per second for about 3 seconds. The noise is very noticeable, I started the truck with remote start from 50 feet away and still heard it. I don't think the knocking is piston slap, since after the first couple of seconds the engine is completely quiet and smooth. Does anyone else in the colder climate areas experience this noise? Is it due to the lack of oil pressure on start up? Suggestions? I don't think there is anything wrong with the motor, just seeing if others have experienced this. Thanks for the help.
Matt
Welcome to
If you have an older truck (~2000-2002) I would say piston slap. But a 2007 already making noise......I'd be back to the dealership for sure.
Welcome to
Dam...I thought GM got their heads out!
Apparently not...I'm not hearing good reports on the 07's
Matt
This doc does not pertain to your truck but it may help you.
Document ID# 1822727
2007 Cadillac Escalade
Subject: Cold Start Lifter Noise - keywords 6.2 arm engine knock L92 oil pressure push pushrod rattle rocker rod starting tick up valve
Models: 2007 Cadillac Escalade
Equipped with the 6.2L Engine RPO Code L92
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The customer concern may be a cold start lifter noise that lasts only 1 to 3 seconds.
Recommendation/Instructions:
Verify the customer concern of a short duration cold start lifter noise. Compare the noise to a like vehicle with a 6.2L engine. The short duration lifter noise is not detrimental to the performance, reliability or durability of the engine. No engine mechanical repairs should be attempted for a noise lasting only a few seconds.
If a small air pocket is present at the lifter during initial start-up, a lifter noise may be heard. If the customer feels the cold start noise is excessive, change the oil with the Mobil 1 5W30 synthetic oil and evaluate the noise.
Note: All L92 6.2 engines built after 3/3/06 are filled with Mobil 1 at the assembly plant.
TBLAZER,
Thanks for the reply and that seems to be the exact condition I have with the 5.3. Do you have any documentation relating this condition to the 5.3L? Would the 6.2L have most of the same internal engine components as 5.3L, just a different bore/stroke?
Matt
TBLAZER,
Matt
No,I could not find any doc's on the 5.3,and yes the 4.8,5.3,6.0 and 6.2 are based on the same design engine block ane heads,they are built with different internal components to change displacement and the way the operate for different applications.
Have you changed the oil and filter? If soo,did you use the original GM type filter?
TBLAZER,
This noise was occurring on the factory fill oil at ~2000 miles. I changed the oil and filter at 2,100 miles with GM oil and ACDelco filter. Since the oil change, I have not started the truck on days as cold as the ones I have heard the noise on. The factory oil was actually pretty dirty when I changed it. Do you know if GM uses any special wieght oil or additives to help with break in? I just hope the noise I am hearing is normal; I had a Subaru that I traded in on the truck that had a cold start knock and that engine failed at 8,000 miles. I'm a little paranoid about these noises after that experience.
Matt
why is every thing normal to chevy and gm when it come's to there car's and truck's. when you spend 30,000 dollar's on a truck you don't exspect it to sound like a twenty year old truck that's ready to die. no wonder why there losing money
TBLAZER,
Matt
I dont know of if GM uses a special break in oil,I don't think they do,but GM does not recomend the use of any additives,It is a good idea to take it to the dealer and at least get it documented,Just in case,The current generation of GM engines are excelent engines and have a very small failure record,since it was introduce in the 1997 corvett it's been upgraded and many of the faults have been corrected,thats why GM is backing them up with 100'000 miles.
    juggernautusa
    juggernautusa
  • Who's Online   2 Members, 0 Anonymous, 499 Guests (See full list)
