Fog Light Trick For 2006 Silverado
my truck calls for a 9145 (H 10) bulb for the fog light. Which has proven to be hard to find around here. And I haven't found anything I like online.So I just used a 9005 bulb in my fog light fits like a champ and is brighter. No cutting or grinding just slips right in. I will repost after I get a chance to use them as to the heat and if the bulbs damage the housing or lens. :crackup: May works for others worth a look if you have run into the same problem as I have.
