Did I Get The Right Part Number?
Had my wife swing by the dealer to grab me a rear differential gasket for the '04 'burb. I have always used a 26066456 (gave her this part #), and she came home with a 15807693, saying that is what the part now is. Both apear to be good numbers on gmpartsdirect, but the later is a few $ cheaper?? Just want to be sure I have the correct part # before tearing it down.
Thanks for any insight!!!
