Ooga Horn W/one Wire
So I have an ooga horn, haven't tried it out yet. It only has one wire, I'm guessing it's for power. Will it be grounded when it's bolted to my truck? I don't know much about electronics, thanks.
That horn should be grounded when you bolt it on.
If you mount it to something that is not chassis ground,
then just run a #12 lead from the horn mounting bolt to
a good chassis ground point. BTW, a relay is a must.
Also, you should remove the paint on the contact surface.
sounds like an old horn.....as long as you mount it on a metal surface that should ground it, if you mount it elsewhere just make a ground wire from the mounting bolt to another metal surface that is grounded. Good Luck...............
You'll have to post a sound clip once you have the horn installed. ;)
    overspeed
    overspeed
  • Who's Online   2 Members, 0 Anonymous, 305 Guests (See full list)
