Carfax Data Question
I am looking at an 03 GMC 1500HD, 1GTGC13U23F124914. Carfax lists it as a initially a leased vehcile, then it was sold at auction and listed as a fleet vehicle. Just wondering what a fleet vehicle is. Thanks in advance as always.
9/2002 Title issued or updated
Registration issued or renewed
First owner reported
Loan or lien reported
Registered as lease vehicle
12/2006 Sold at auction
in Georgia
Listed as
a fleet vehicle
01/09/2007 Vehicle offered for sale
A fleet vehicle is one that was owned by a company or the government. It was part of a fleet purchase (say they come in and buy 10 or 20 or even 50 trucks at once for a discounted price). I wouldn't be surprised if the lease reported was also the same owner as the fleet. I've seen that happen before. The fleet owner may have bought out the lease for what ever reason at the end of the term. It may have really only had one owner.
Since it was listed as being sold at an auction it has probably had two owners. Most fleet vehicles are well maintained - but could also be driven by many different people in the course of a week. What condition is it in ? - how many miles? etc. It could be a steal or a no-deal.
The truck has 44,000 miles. It looks pretty good from the pictures. That is as far as I have gotten with it. I am suspicious of "Leased" vehicles.
No need to be, IMO. I've leased a couple of cars in the past. There is some incentive to make sure nothing goes wrong on them. You are limited in your mileage or you pay more. When you turn it in they go over it with a fine tooth comb and will ding you for any dings, so to speak. There's a certain amount of pressure to take care of it. Least that was on my mind when I did it. Leasing itself is a whole different issue. I'd try to avoid leasing a vehicle, but I wouldn't avoid a leased vehicle.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
