Howdy From Silverdale
mcaje
Hello from cloudy Silverdale Washington.
I've grew up in Southern California :D but the Navy :D brought me to the Pacific NorthWest 20 years ago. I live here with my lovely wife and our 15 year old daughter.
Well here's my ride. :) I put the Nerf Bars on this earlier this week. I'm looking forward to getting some cool :jester: ideas on a few upgrades from the rest of you.
Be talkin' to ya. :D
Nice truck, welcome aboard
Thanks Bill.
I really am serious about soliciting sugestions from other members of this community as to some "Conservative" upgrades for my Truck.
I am always on the look out for better than OEM replacement parts and upgrades. My Google searches kept coming up with this site as the top forum for just that sort of thing.
Mitch
Nice truck! Are you going after looks or performance or both? If performance, look into a tune to wake up your truck and possibly get better gas mileage (if you can keep your foot out of it). Well worth it in my opinion.
A little bit of both I guess.
I like a nice clean look so the only real upgrades I looking at now are things like dash trim kits or Denali trim pieces.
As for performance, I want whatever is better than stock. Currently I am looking at plugs, wires, shocks, exhaust and brakes.
I'd like to get some more altitude (even an inch or two), but I'm afraid of spending hundreds of dollars to ruin that sweet Z71 ride.
I'd appreciate any proven results-type advice.
Welcome Squidley!!! I was at PSNS from 91-95, what's your rate? You have lots of options for your truck and all of what you want to do can be done pretty cheaply. Ask away about specifics and do some searches, there's tons of info here. Welcome!!
Missile Technician Chief.
Been here since '88. I've done tours on the Ohio, Georgia and Alaska.
I love searching through the topics looking at what everyone has to say on various subjects. Cool forum!
Superbee, you sure got a lot of toys. Judging by the list, I'd say you live in hills of Penn.
Here in Washington I'm surrounded by water so my toy list looks something like this.
1998 26' Macgregor power sailer w/ Suzuki 4-Stroke 50
1996 14' Seadoo Jet boat
1995 Yamaha 700 Jet ski
Additionally we have an Audi A6 and BMW z3, but that's rather inconsequential to this forum.
Welcome to the site.
You got a good looking truck too.
Thank you S-Ten. I like em' clean.
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
