2" Drop Shackles = Level
I have an 03 'rado will the 2" drop shackles make me level?
if not what does?? and will I need anything else to go with it, like pinion angle shims, new shocks Etc.
Thanks
Aiden
no you dont really need new shocks. I have the 2" shackles installed in my 03 GMC.
they will get the truck close to level, but not exactly. my truck still has about an inch of difference between the front and back. but not enough to notice. you shouldn't need any shims or anything either. not for just a 2" drop.
cool....Thanks man
You wouldn't happen to have pics of your truck would you, I just want to see how much it closes the gap up between tire and body.
yeah sure. let me get the forum link for ya.
here is one with the drop. not sure if you can tell it or not.
Pic 1
and here is the original pictures:
Original pic
Thanks man
Thats exactly what I'm going after...something thats just barely noticeable, but you can tell its different.
That is one clean ass truck BTW projectors are bomb man...I like.
So....I got a price on some Belltech shackles tonight...$65 CAD...how hard are they to install....do I need a lift or is it something I can do in my driveway?
floor jack, wrenches, impact wrench, and jack stands.
jack the truck up, set the frame on the jack stands, then let the floor jack down so the rear end hangs down to take the load off the springs.
then just take the two bolts off the back holding the shackle on. if you have the towing package with the bumper mount hitch, you will have to take that off to get the top shackle bolt off....
extra work, but makes like a lot easier.
and thats really all it takes. that gets the high points, everything else is really easy. once i figured out how to do it, the drivers side took a total of about 10 mins to do. passenger side? first try? 45 mins. lol
Yup, first time I did it, it was about 45 minutes to an hour.
The second time I put those things on, it was more like 15-20 minutes before my buddy was backing out of my driveway and I was sucking down some free suds while nursing my busted knuckle. :confused:
  • 2 months later...
  • 4 weeks later...
MINE WAS PERFECT!
Does anybody know a source to get these a rear drop shackle kit for the 2007 NBS Sierra?
My 2WD crew cab sits up in the back like a rabbit and I'd like to get it down to level.
  • 3 weeks later...
MINE WAS PERFECT!
I used Bell Tech 99 - 07 old body style 2" shackles on my NBS GMC and had no problems at all with the fit. It looks better and rides great.
MINE WAS PERFECT!
I got a set from StylinTrucks.com for about $45 (for a friends truck). But if I were you, I'd look around. My bank froze my credit card because evidently, StylinTrucks has had lots of stolen card issues or something. It only took a few minutes to get it unlocked, but I don't have a warm-fuzzy about having done business with them.
MINE WAS PERFECT!
I still don't get how you got those on without unbolting the bed.
I'm doing another tomorrow...I'll try it again without unbolting it, but I'll not hold my breath :wtf:
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
