Inverter Mounting?
I'm looking to mount a little power inverter somewhere on my '07 Classic 1/2 ton. I just need a little light duty one like this one. My question is, would these be OK to mount under the hood or would the heat just melt the plastic parts? I don't intend to actually use the inverter while driving the truck, but only when the truck is parked and the hood is up. Just need one that can sit under there without melting.
I see no problem in mounting under the hood, they produce their own heat so i am sure it is not much of a worry. Just be sure to keep it away from moving parts and extreme heat.
