Can Someone Find Me A Bulletin ?
For my 2005 HD...the outside door molding is fading baaad and the paint is gone....service guy thought there was a bulletin on it but couldn't find one....anyone know if one does exist ?
Thanks !
The only thing I found related to the badging.....
Body - Exterior Emblem Discoloration/Peeling/Blistering
Bulletin No.: 06-08-111-004
Date: September 08, 2006
INFORMATION
Subject:
Information on Discoloration, Blistering, Peeling or Erosion of Various Exterior Emblems Including the Chevy Bowtie
Models:
2007 and Prior GM Passenger Cars and Light/Medium Duty Trucks (including Saturn)
2003-2007 HUMMER H2
2006-2007 HUMMER H3
2005-2007 Saab 9-7X
Chemical Discoloration of Badges
Through warranty reviews and visits to dealership storage lots, it has been determined that certain chemicals may discolor exterior badging. The badges most likely to be affected are referred to as Second Surface Acrylic Emblems. These emblems have a clear lens over the painted portion that lends depth to the badge. Several aggressive cleaners have been identified that when allowed to soak the emblem may migrate under the lens and discolor it.
Butyl Cellusolve
This chemical is one of the most likely to harm badges. This chemical is found in several cleaning products such as Simple Green, RainX, Orange Blast Wheel Cleaner, Purple Power Engine Degreaser and many others. Most of these products have warnings about contact with plastics. Further, these products generally are not intended for use as a cleaner of painted surfaces. The exception is Rain X which if added to the washer reservoir may be dispersed into emblems from rear wiper/washers. Avoid the use of Butyl Cellusolve altogether.
Always use mild soap and water as a first step whenever cleaning a vehicle.
Other Chemical Concerns
The following three chemicals may also harm plastic emblems:
Oxalic Acid
Dihydrate Techorganic Acid
Hydroflorides
Contact with these chemicals is sometimes associated with products intended to clean bug marks off vehicles, as well as in diluted form in some commercial car washes.
When using any cleaners on exterior emblems, DO NOT soak the application rag. In some cases the cleaner may not harm the badge if used sparingly and not allowed to seep into the lens of the emblem. Always use mild soap and water as a first step whenever cleaning a vehicle.
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
