Fs: Alpine Iva-w200 Double Din
Selling my 9 month old Alpine IVA-W200. Selling with iPod cable, TR7 bypass, XM box, install bracketry, GM wire harness already hooked up. Everything that was in the box new will be in the box. Flawless unit, just has some finger smudges on it. Absolutely no problems with it at all. Im just moving on to something different so its time for it to go. Gonna ask $600 plus a few bucks for shipping.
