2007 Gmc Sierra Nbs Ecm/tcm Updates
BigRedTruck
I have a new 2007 GMC Sierra ext Cab, 6.0L, which was built some time early May 2007.
I'm not sure if my truck has this version or an earlier version of ECM/TCM code.
:) Is there any way from a end user that we can see what version of code is loaded through the information center internal to the vehicle?
Thanks
See TSB Below:
QUOTE(GeoHawk @ Jun 26 2007, 03:04 PM) *
Actually it looks like there is a TSB for this condition. I'd wait a few hundred more miles to see if things smooth out, but if it's still doing it take it in to have the ECM/TCM reprogrammed:
Document ID# 1969002
2007 Chevrolet Silverado - 4WD
Subject: L76 4L60-E, 4L70-E Chuggle, Surge or Hesitation May be Felt with Active Fuel Management System Cylinder Deactivation Transition from V8 Mode to V4 Mode (Reprogram ECM and TCM) #07-06-04-013 - (05/04/2007)
Models: 2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon, Yukon XL
with Active Fuel Management System Vortec® GEN IV 6.0L V8 Engine (VIN Y -- RPO L76)
and
HYDRA-MATIC® 4L60-E, 4L70-E Transmission (RPOs M30, M70)
Condition
Some customers may comment on a chuggle, surge or hesitation felt during an Active Fuel Management System (AFM) cylinder deactivation transition point .
Correction
Before reprogramming the ECM and TCM, compare the vehicle to a like vehicle. This may be a normal condition for an Active Fuel Management System equipped vehicle and no repairs should be attempted. The vehicle you are evaluating may be a little harsh in AFM transition. A calibration update was released for the ECM and TCM to soften the feel of the AFM transition.
SPS Information
• ECM -- New calibration to address customer concern of bump during active fuel management transitions. Must also program TCM with latest calibrations.
• TCM -- New operating system and calibrations to improve engine performance and shift quality. You must also program the ECM with latest calibrations.
Reprogram the ECM and TCM with the latest calibrations if the above concern is encountered. Updated ECM and TCM calibrations are now available to address this concern. These calibrations, or any that follow, are designed to address this concern. Refer to Service Programming System (SPS) using the appropriate Service Information (SI) procedures. The new ECM and TCM calibrations will be available to dealerships as part of TIS2000 incremental satellite update version 4.5, for 2007 (available on 04/23/07), and on TIS DVD version 5.0/2007 or later, which will be mailed to dealers on 05/09/2007. If you cannot access the calibration, call the Techline Customer Support Center and it will be provided. As always, make sure your Tech 2® is updated with the latest software version.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
