Opinions On Paintless Dent Removal
I have a small dent on my driver's side rear door. It is about 1" dia maximum. A go-kart up on a portable kart stand rolled into my truck. It dented the door and transferred some of its blue paint onto my truck's white paint. I was curious about PDR services to remove the dent. Does anybody have any PDR opinions or experiences?
When I get the dent taken care of, how do I get the blue paint removed from my white paint? I believe that the blue in in my clearcoat.
Any help is appreciated.
A reputable PDR guy will look at the dent and tell you if he can get it out. Typically, as long as there is no crease, they can usually take care of it. The blue paint will probably come off easily and he will take care of it.
I have used it before and have been very impressed. Just use someone who has a good reputation.
Go to the Mercedes dealership and ask them who they use.
DEWFPO
IMO anytime you can repair a body panel with out filler your better off. I worked at a shop where they would have PDR guy remove any dings/dents even if they where repainting the complete car/truck.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
