Help...engine Noise Question
Thinking about purchasing a 1995 GMC Suburban 1500 with a 5.7 350 K engine. Throttle body injected, 2-wheel drive.
Truck has 112k miles on it. Dealer (My employer) is waiting to hear a response if I want to purchase. I have checked this truck out at work (New-Car store-this truck is a trade)
ONE thing sorta holding me back. While driving the truck OR sitting in park, if you snap the throttle, aroung 1800 rpm's I am hearing a
Rod knock??
Wristpin??
Piston Slap??
OK...here's the kicker...2000 rpm's and above...THERE IS NO ENGINE NOISE.
At cold engine start...overnight...NO ENGINE NOISE
At idle...engine hot...NO ENGINE NOISE
Am I hearing a rod-bearing on it's way out?? Am I hearing NOTHING UNUSUAL???
Another tech listened to the noise yesterday...which mainly occurs when ENGINE IS HOT, and he stated "...it sounds too "tinny" to be a rod bearing. Check the torque converter bolts."
So, after work I pulled it in the shop, and all the torque converter bolts are perfect. No cracked flywheel. No leaks under the truck. I also changed oil and filter. NOTHING found in the oil or filter.
What in the world am I hearing??
I always thought these 350 K engines were BULLETPROOF.
As stated earlier...at 1800 rpms the noise is most prominent. Oh...awesome oil pressure too...40 psi when HOT at idle.
Do these old throttle body engines "loosen-up" when they get miles on them?? Is this engine gonna break??
Should a different type of engine oil / additive be used????
HELP - input needed.
My buddy has one of these, only his is a 4 wheel drive. It has the same problem and has for about 2 years now. We have stripped it down, looked at everything and replaced all the bearings, Rings, and gaskets. The noise stopped for mabey a day and came back. Personally i think that it may be nothing to major.
Possibly a wrist-pin with some play in it??
99silverado99...THANKS for easing my mind a bit. I thought I was the only guy in the USA to hear this sound...
Wish we could get some engine experts in here...
    mighty K20
    mighty K20
  • Who's Online   4 Members, 0 Anonymous, 566 Guests (See full list)
