Shifting Hard At Highway Speeds
golfballs
My 2000 g2500 savana shifts hard when im at highway speeds for a while. When i slow down to an speed it still shifts hard. All i have to do is turn off the vechicle and re-start it and its fine with no hard shifting at all. Can anyone help me with this issue. Thank you!
You need to have it scanned for codes. It is going to full line pressure. Fix the code and it will fix the hard shift problem.
Chevytech007
Thank you for responding, i have no codes, the ses light dosnt come on and there is no prelim code also. Could there be a code that only the dealer can see ?
Again thank you.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
