Wtb: Center Caps
So..I took my truck down to Wally to get some tires put on, and before the guy finishes up he comes back to show me one of my center caps. He tells me that they are all broken because of age and heat. Personally I think they broke them with the air wrench, but since I can't really prove anything I guess it doens't matter.
At any rate, I'm looking to buy a set of center caps for a 94-98 Silverado rally wheel. Silver or black. Looking to spend between $20-30.
Thanks a lot fellas.
