2007VMAX Posted August 21, 2007 Posted August 21, 2007 I installed a leveling kit on my 07 Vmax 2.5" front and 1.5" rear. After install truck drove 100% straight no pulling other than sitting up higher absolutely no difference. Just to be safe I spent $49.95 on a Laser alignment truck was still well within factory specs, 1/64" out not even enough to put a wrench to! So I am either lucky or spacers do not affect alignment? Anyone else run into the same thing? If I could figure out how to download pics I would HAHA!
kdogg Posted August 21, 2007 Posted August 21, 2007 Mine went in today. It deffinatly needs aligned. It's toed in. It didn't pull either way ecept on the freeway but in slow turns you can feel it wanting to turn sharper than it should.
04z71steve Posted August 21, 2007 Posted August 21, 2007 When i cranked my tb's to get that extra 2" to level her out, she didn't pull at all, had her checked and she was fine, so i really don't know exactly what you have to do i guess you just get lucky sometimes when you don't need to have it aligned...
2007VMAX Posted August 21, 2007 Author Posted August 21, 2007 If anyone can help with adding pics to a post I will give info on lift and show some pics? Thanks
kdogg Posted August 21, 2007 Posted August 21, 2007 If anyone can help with adding pics to a post I will give info on lift and show some pics? Thanks OK.... Go to cardomain.com create a profile and add your pictures there. Then open the picture once it's on the site. Right click, select properties, highlight and copy the URL. Then come back here to your post or reply and click on the little icon with the sun coming up over the mountains. Paste your URL there and click ok. Try that.
2007VMAX Posted August 21, 2007 Author Posted August 21, 2007 If anyone can help with adding pics to a post I will give info on lift and show some pics? Thanks OK.... Go to cardomain.com create a profile and add your pictures there. Then open the picture once it's on the site. Right click, select properties, highlight and copy the URL. Then come back here to your post or reply and click on the little icon with the sun coming up over the mountains. Paste your URL there and click ok. Try that. Thanks
kdogg Posted August 21, 2007 Posted August 21, 2007 Mine went in today. It deffinatly needs aligned. It's toed in. It didn't pull either way ecept on the freeway but in slow turns you can feel it wanting to turn sharper than it should. Darn the dealer caught the Spacers They just called, no free alignment. Now where do I go?
