Thinking About Getting A Plow- Will It Hurt The Truck?
MKWL
I'm thinking about getting an 8' Fisher plow for my truck. I am wondering who else on here plows with a 2500HD, and the kinds of things that were badly with a plow. Is the trans an issue with plowing? I have plow prep BTW.
Thnaks in advance,
Matt
From my experience, the typical wearable parts do wear faster with a plow, but that all depends on how much you drive around with it. Nothing should "break," but your tires, shocks, and brakes have to work harder and differently, so they could wear faster. Your truck is made to operate with a plow, so go for it.
I plow. I have a 7 1/2 ft Western Pro with wings. It was on my 01 HD and I will be transferring it over to my 04. On my truck I cranked the torsion bars up, use Timbrens in the front and use ballast in the back. All 3 of these will help keep the front end from sagging with the plow raised. As for the rest of the truck. WAIT til the truck has come to a complete stop before shifting from reverse to drive and back again. When I plow I have the truck in 4hi, tow/haul on and just for piece of mind I drop it into 3rd. It never hurts to let the truck sit in neutral after you've done a couple larger lots while you catch up on paper work or are on the phone. With it in neutral, the pump will still circulate the fluid to help cool the tranny. The way I understand it, when the truck is in park, the fluid won't circulate. I could be wrong on that but not 100% sure. Take your time and dont be ramming piles and jammin gears. Check out these sites for some good snow plowing info. I'm a member of both(they are free)
www.letstalksnow.com/forums
www.plowsite.com
My general rule is to never purchase a used vehicle that I know has been used for plowing snow. And same for truck used for daily towing (not talking RV stuff here, I'm talking about the truck that has fifth wheel trailer with backhoe in tow every day, or one that's been on the farm pulling round bales every day).
Why, because as previous poster said, they will wear out parts faster with that kind of use.
Yes, but the motor and tranny will be broke in for that kind of driving if that's what you are going to use it for. Brakes and tires are cheap to replace.
My truck has been towing since the first week I had it and it is one of the best trucks we have had. Actually that's why I still have it. i have seen alot of trucks broke in lightly as daily drivers and then used to tow with a second owner just to have the tranny go out soon after.
No science or testing involved here, just real world observations.
www.plowsite.com
Good reply and great tips! :thumbs::confused::tear:
  • 3 weeks later...
Thnaks in advance,
Matt
I've been plowing for about 20 years now. In my experience it's not the plow that hurts the truck but how you plow... :rolleyes:
If you don't really need the plow, then don't get one. It's a whole lot cheaper to hire someone else to do it and let their truck take the beating. I had a plow on my last 4 or 5 trucks and with this one...I said no way. It was one thing after another breaking and needing service. Either hire someone to do it, or get a tractor, beater plow truck, snow blower or install radiant pavement heat.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
