Help! Doors Unlock Themselves
Hi all,
I have recently discovered a very intermittent problem with my automatic door locks after replacing my original factory battery that died (03 Silverado LT). The doors unlock themselves ever so often when I'm driving down the road, but so far this has only occurred when a large bump is encountered. So far it has only occurred when crossing a set of railroad tracks or sometimes the track for the gate at the front of my apartments (which sits up out of the pavement a little bit and causes a suspension jounce). The problem is very intermittent, as it has only occurred a couple different times in the past couple weeks. However, on one of those drives the door locks unlocked 3 or 4 different times as I travelled around. The door locks do not repeatedly cycle or continue to try to unlock - it is just a one time cycle and they are unlocked and that's it until the next bump that hits just right.
I don't know if the original factory battery death has anything to do with the issue or not, but I never noticed the problem until after the battery was replaced. When the battery died I had to get a jump start once from a portable jump start power pack to get home from work. Once I got home the battery was replaced and shortly thereafter the doors began to unlock on their own
My first thought is that it's probably just a ground issue at the battery - but this would lead me to believe that other odd things would be happening too - but I have not observed any other problems. Another option I thought of is that I didn't jump start it right (pos to pos and neg to neg) and something got messed up - but again I would think there would be damage other than just an intermittent door unlock.
What do you guys think the problem might be?
I dont know but my trucks doors locked by itself 3 times so far. I leave the keys in the ignition in my driveway all the time and thats when it was happening- lucky I either had the windows down or I was able to get my spares in the house and didnt get stuck any place.
He needs a huge sig thats a huge truck! I'm jealous. As for the locks I guess that something could have happened to the ecu with a bad jump.... Did you go neg to neg or neg to ground? Couldnt find any TSB's replicating this issue, I'd say take it to the dealer but you just know that they wont be able to replicate the problem, and won't do anything unless they see it...
When I jumped it, I used a jump start power pack - one of those portable little boxes that has a pos and neg cable on it and you just hook it up, no other car is needed. I connected the POS to POS and the NEG to NEG rather than connecting the NEG to GROUND (frame, etc.).
I don't have an extended warranty so that's out... and like was said, it is so intermittent a dealer would prob never duplicate the issue.
Also, last year I had an electronics store install a remote start system but they could never get it to work right for more than a couple starts. The system would get messed up and start locking/unlocking the doors and set the alarm off at random when the truck was running. I had them take the system out after a half dozen trips to the store for repairs but there could be some residual electrical hacks they did not fix properly that are just now showing up... dunno. I would take it back to the store but they are halfway across the country now that I have moved.
I'm hoping there is someone here who has enough knowledge of the systems to tell me where to start... are the locks controlled by the BCM (should I start here)? Should I be looking for a rusty ground connection in the door or something? For those of you who are knowledgeable about remote starts, where are some places I should look where the remote start installer might have stripped some wires during the installation process?
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
