some pics of my silv. for you guys
tony41z71
its nothing too original, its got k&n goodies, flowmaster 40 series, 3 inch stainless steel pipe from the cat back, billet grill, pollished bowtie, 265 bfg at ko's, apline goodies inside the cab, hill4wheel leveling kit, and other small stuff.  but, i like it, i'll have to take some more pictures when it's clean.  adios
<img src="C:\My Documents\My Pictures\tony first 011.jpg" border="0"><img src="C:\My Documents\My Pictures\tony first 014.jpg" border="0"><img src="C:\My Documents\My Pictures\tony first 013.jpg" border="0"><img src="C:\My Documents\My Pictures\truck3.jpg" border="0"><img src="C:\My Documents\My Pictures\truck1.jpg" border="0">
Welcome!! :thumbs:  Sounds like you have a nice truck. You cannot post pics from you hard drive, you have to have them on a website. Try picturetrail.com, you can post them there for free or one of the many other sites. Picturetrail does allow you to post you pics here so that is a good one.
                                                  Chris
First of all, welcome to the forum.....You cannot post pics from your computer.  You have to have them hosted somewhere.
EDIT---hehe.....looks like you beat me to it Yont283
:thumbs:
how do i upload onto the post?  i think i screwed my first post up
thanks
you have to post the pics somewhere on the web (picturetrail works).  Then you just post the URL to that picture wherever it happens to be hosted from and voila.
No problem....Any place on the web will work that can host your pics.  So if your ISP lets you have webspace, that will work too, although some places will not let you link from an external site.  Have fun :thumbs:
Hey, that is my truck!! :thumbs: Nice truck!  :(  You can post the pics directly on the website if you go to more options under members area and then click on url's for auctions. Then you copy that URL and put it over here. If you have any trouble, just ask me.
                                 Chris  :D
man, you got smoked Tobes, j/k  :)  :)
i'm really not planning on too many more mods, i'd like to do a spray in bed liner.  take the front windows from 15% down to 5%, even though i know the cops will all look at me funny.  but, i'm not going to do much else, suspension lifts look good, but i've had really bad luck with them in the past and i love the stock ride.  so, pretty much what you see is the way it is going to stay.  unless......someone has a pair of 16x8 6x5.5 weld typhoons that they would like to give me!  ha, anyway, thanks for the compliments guys, you're trucks are all totally kickass too.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
