Pics from offroading
HillHound
Well finally got some pics developed from when I went off-roading and found some nice mud in a wash/detention basin the county is building out in the mountains...
Pretty messy under the hood when I was done.  Happy I didn't have an open air filter, otherwide it would have been dirty.  Took me many hours to clean though, especially the bottom of the truck.  But it was fun.
:thumbs:
Good photos Sincity!  I don't mind getting the truck dirty at all but man I hate mud in the engine area!  Were you able to get most of the mud off of that insulation attached to the underside of the hood?
Looks like you had fun! :thumbs:
Yeah, busted out the power washer at home and went to work cleaning the truck up.  Actually took me a couple of days wash it between doing other things.  The undercarriage is what took the most to clean.  The engine bay is pretty clean now, but needs just a little more work when I have the time, just that dirty water film left on a few parts.
Wanted to get some action pics, but kinda hard to drive and take pics.  And I didn't want to get my good sandals all muddy.
Good pics. :thumbs:
Here's a tip for undercariage cleaning.  Set one of those spriklers that goes back and forth, the fan shaped kind, under the truck.  It will get alot of stuff off and make your time spend under the truck a lot less as well as easier.  It's kind of along the same lines as using a leaf blower to dry of the truck with...it can get some funny looks from neighbors.   :(
Definatly good that you didn't have and open air filter.  ;)
That's what you bring a buddy for. :(
Never the less, great pics.   :thumbs:
those pics are nice dude!  flly on over to my pics site and check out the first picture on top.  its the dirtiest pic that i've ever got of my truck.  i'm very proud of it =)  it took me about 5 hrs to get all the mud off the truck and underbody, and i refused to go to a carwash, and so when i was done there was like a 6 inch mud blanket on our driveway!  my roommates who have smaller cars and park in the garage are like, "dude, tony, you better clean all that sh*t up, my porsche doesn't have a Z71 package and i kinda need to get it into the garage!"  haha, and in good fun!
my pictures
my pictures
LOL...yeah I know what you mean about a muddy drive way.  My dad gave me a few dirty looks for the mess I made cause I too refused to go to a car wash.  The gutters had a few inches of mud stacked up in them, and all of the neighbors driveways downstream of our house had mud water in the gutters, so the neighborhood was full of muddy tire marks, and still is actually.   :thumbs:
Tom, that is a really good idea, I am going to try that out for sure next time I need to clean the undercarriage.  That would make life alot easier and keep me a lot cleaner then if I have to crawl underneath the whole time.  Thanks.  :thumbs:
General, next time I go out there I will definately bring someone along to get pics, this was just a spur of the moment thing while I was out driving around.
Thanks, I've been doing that for years.  It doesn't get everything, but it helps out a lot.  And if your lucky enough to do that before it dries up completely, it helps even more.  I move it around into 3-4 different spots over an hour or so time, to try to get the most of it off.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
