'07 Suburban - Same Lugnuts For Steel Wheels?
I just bought a set of winter tires mounted on 17" GM steel wheels and was wondering if I can use the OE lugnuts from the alloy wheels, or if GM makes different ones for the steelies.
The company I bought the wheels from shipped me a set of new lugnuts, but they're not double-threaded, so I can't use them with the GM centre caps.
Also, the wheels are take-offs and have a few scratches. Does anyone know the paint code for these - they're not chromed, but kind of a silver/grey.
In case anybody else was wondering, it looks like all the GM lugnuts are the same for both the steel and alloy wheels. At least, that's the advice I got from my local GM service department.
Not sure, but maybe it was a silly question for a truck forum? :( Oh well - thought I'd ask, becasue I did run into the problem once before when I put some steel wheels on my car.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
