07 2500 Hd Oil Plug
wilkins
I have an 07 2500 HD with 6.0 gas engine. I just changed the oil and noticed the oil pan plug has no magnet. Do you know why? The oil filter is a PF48 and seems small. Is there a larger oil filter available? Also the PF48 has a spring like device in the center bottom. Do you know what it is? At first I thought it is a back flow valve but the valve (flap) is in the top of the filter.
thanks, David in Tomball TX
