Buying Denali Need Upgrade Advise
Hello, this is my first post. I currently have a 2005 mustang Saleen and am probably going to trade in for a ~2003 Denali (Black). My plan is to black it out from solid black 22s to the grille and chrome surrounding and a 2/3 lowering kit. I am new to Denalis so I need help. How do you paint the grille and chrome surroundings? I have only found one 22" completley black wheel, American Racing Thresh, is there any others out there? Thanks for the help
so is powder coat the best and only option for the grille and surrounding?
You could have a body shop paint them to match, it might be a bit more expensive but they can match the paint exactly.
Just hit up a body shop and ask them.
I didn't think you could paint over the chrome.
Yes, you can paint over chrome. The body shop you use needs to make sure it is prepped right, sprayed with an etching primer and then a good surface primer before they apply the color and clear. That will help it bond better. Make sure you choose someone that will give you a lifetime paint warranty against flaking or peeling. You will get rock chips, that is just part of having painted parts exposed to road elements.
What kind of paint the factory uses that keeps the rock chips from happening so easily as compared to an aftermarket painted grille. I had the center section of the grille on my 2004 Silverado painted and thats where all the chips showed up - not at the factory painted areas. And I had my grille done at 3 different places - all high end / show qauality shops with the same results.
We deal with that same problem all the time in my shops. Although you can match the factory paint in terms of quality and looks, there aren't any body shops out there that utilize the "same" paint processes as the factory. At the factory, they use a paint system that is sprayed on and then clearcoated, that's where the similarities end. Their systems are more closely aligned to a electro-magnetized method, often seen in powder coating. While it is not a powder coating, the color and clear are for more durable than the aftermarket paint systems offered by PPG, DuPont, Sikkens, Sherwin Williams, etc. They can bake their finishes at a much higher temperature due to the fact that the vehicle is painted as a shell only. In the body shop environment, we go through the process of taking off all of the handles, belt & body side moldings, mirrors, weatherstrips and such, however, much of the vehicle is left in tact and does not allow high temp baking as it would ruin soft parts. On another note, it does help for the body shops to use a flex additive agent in their paint when spraying front end parts that are normally exposed to the rocks and debris. It helps to keep the clear a bit more resilient to the chips, but they will inevitably still occur.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
