Wanted: Obs Extended Cab Rear Seat...
dewai
I need a rear seat for my 97 ext cab. I'll take any color and any year from 88 and up, as long as its in ok condition. Let me know if you have one or any ideas where I can find one. I've checked the pull-a-part by me and they had absolutely nothing. Thanks for your help.
