2001 1500hd Will Not Run
Hi all
this is my 1st post so be gentle...I Have a 2001 1500 HD with a 6.0L(150K miles) and while driving the truck today, it completely stalled while at a stop light. I was able to get the truck up and running but barely....it appears to be only running on a few cylinders and the only code I can get it to pull is P0300 multiple misfire. I thought it may be a bad coil but it should at least idle if only 1 or at the most 2 are bad...I can't get the truck to even idle at all. It will only start if I keep the rev's above 2k rpm, and it stumbles and bucks badly. I checked the fuel pressure as well and the pressure is around 50psi +/_ above 2k-3k rpm, What is the proper fuel pressure supposed to be? Any ideas what else the problem could be?
Thanks
Tim
Easy - had this happen on my truck identical to yours this summer. Identical symptoms, same trouble code. I bet it is hard to start when the engine is warm too eh?
The check and fix - On the left (driver's) side of the intake manifold, pull off the small vacuum line going to the fuel pressure regulator. If fuel runs out of the vacuum line, the regulator is bad. It's a simple 5 minute fix (held on with only the little spring clip).
Took the truck to a local shop where they have diagnosed that the cats are supposedly bad(clogged)...They claim the cats both got red hot once they got it running and so they dropped the exhaust off the manifolds and it will now idle on its own and on all 8.....Will the fuel pressure regulator cause the same simptoms? The shop wants to replace the whole exhaust from the manifolds back........$1800!!!!!!!
no no no dont let them do the exhaust, go & get hi-flow cats installed somewhere else since cats is all the problem should be. and with the rest of exhaust buy a catback or something w/e you would like. Dont let them charge you that much for a stock exhaust
No way should you pay $1800.00 for exhaust. If that is indeed the problem, just buy new cats and if you want, a new muffler while you're at it. If you buy the parts online, you will save a ton. If you have to pay someone to put it all on, it shouldn't be more than 200-300 bucks for labor. You can get a decent muffler (if you need/want to even replace the muffler) for about $100.00 and decent cats for $100.00 or so each too. If you look hard enough you can get it all done for $500-700 bucks, with labor. I would say your muffler and pipes are fine though.
Tell them you'll pay 1800.00 for new exhaust and a '97 Malibu (I just sold an old car of mine for $1200.00).
No 150k truck needs a $1800.00 exhaust-unless you are making a show truck.
It's hard to diagnose over the internet but reason would say that the cats are red because it is running lean due to low fuel pressure.
Troubleshoot and fix the root cause...the first test is putting a gauge and measuring the fuel pressure at the rail.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
