Blazer Zr2 Wheels
I just got a 2000 Blazer ZR2 and it has the stock aluminum wheels which are OK but I'd like some black "rock crawler" type of wheels. I have the 31X10.5 Tires and tried some new wheels but they stick out too much and rub. I was told I would need 50MM offset wheels and thats almost like a FWD car. Can I go with a smaller tire? What would be the largest tire size I could go with without rubbing? And what wheel could I go with???? I've seen some real nice wheels on ZR2 Blazers. I guess this is all because of our IFS on our trucks??? Any help is appreciated! :thumbs::banghead:
You need to checkout ZR2USA.com
To answer you question the largest tire you can fit on your Blazer ZR2 without a lift is a 31x10.5. The stock rims have a factory offset of 6". Ideally you do not want to get a rim with less than 4 3/4" back space. Unless you get the stock backspacing though, your likely to rub without a lift.
