Newbie Looking For Advise
Hey all, first post here! Just bought a 2008 Sierra Danali ( I am pretty excited, great job GM!) I have always bean a big diesel guy and just traded in my 2005 F-250. With diesel actually costing more than gas (Figure how that can happen?) I figured there was no use for my diesel truck anymore since I really don't tow a hole lot.....Anyways I have always been a big mod guy, how does GMC react to modification (headers, exhaust, intakes, tuners) and what manufacturers do you guys recommend. I am familiar with Diablo and some other tuners. It looks like Injen makes a nice CAI for my truck. ANy problem with the air flow sensor.
There is a problem with using an oiled filter with the mass air flow sensor, GM Perfomance parts is starting to offer dry cai.
I'd skip the handhelds. If you can get good with HPTuners (horse power tuners), you'll be in the 13's @ close to 100mph (1/4 mile) with a cat back, intake, and tuning (need/highly reccomend a lap top computer for that). Depending on sea level elevation of course. I'm not big on 6.2's but I do know custom tuning can throw Denali's in the high 13's/DEEP 14's. If your more into modding I'd look into cams, if they have them for 6.2's.
edit: Outlaw makes a great intake for trucks. It uses an airbox so you don't indulge under hood heat 100%, and uses a dry filter that you can litterally wash with water and/or blow out with an air compressor and reuse.
Thanks, I never heard of outlaw intakes before, I always used AFE for my trucks and I did use an Injen intake for my Nissan before. I am pretty sharp with tuners/laptops just from modding my last 2 diesel trucks. Diablo kind of has a bad name in the diesel world expecially with Ford owners(blowing head gaskets, too high of CP's),but I see a lot of people on here use them a lot.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
    • It’s at the point of amusement. I’m retired I have time. It’s fun seeing people try to convince me I’m using oil. I’m buying oil at the prescribed time. It gets drained and new goes in. Do I add in between, no. My oil doesn’t even get dirty in 5k miles. I don’t even see any drop on the stick. I check in the same place. All is well.
