2008 Horn Honk
if its locked on the outside them opened from the inside it will, and most likely will if locked on the inside & opened from the outside, just gotta make sure if its locked outside, open it from outside, and shouldn't have to lock it from inside shifting out of gear does that for you and unlocks when parked.
The manual covers it as I discovered the same issue. I know using the keyless will prevent the horn from going off. If you use the key, it'll start beeping, but then stop if you hit the power unlock button on the door.
When unlocking the door on the new 2008 Chevys, how do you keep the horn from honking like I'm stealing the vehicle? This is very frustrating!!!
Lock the doors manually and don't use the remote to lock the truck. Using the power lock switch and /or the remote to lock the truck sets the alarm. When you unlock using the key it senses a break in. I seem to remember you can turn the horn off in the DIC settings for "alarm response"...
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,180 Guests (See full list)
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
