Autotrac Noise
timbercutter1
We have a 2004 Yukon lt with Autotrac which has always had noise which we were told was "normal". Now with just under 50,000 miles it is easy to here the transfer case load and unload at very light application of power running at 40-45mph on level ground. The noise has changed from a whine to a growl and can actually be felt in the wheel and pedals. Reminds me of a wheel bearing on the way out but this is not from a wheel but rather in the middle of the car. Dealer said that there isn't anything to repair, but to wait for it to "blow up and destroy itself"
Does this seem plausible? I wish it had happened while under warranty when we had it in 3 times for the noise.
What do you recommend doing?
Thanks
Timbercutter1
I have the autotrack in a new sierra denali with 6.2 L and the 6 speed. problem i have is a clunk in the rear end when accellerate from a stop. clunks immediately and before it shifts to 2nd gear. have you had any trouble with a clunking noise similar to this. Rog
I would go in and complain to the dealer that you had brought the vehicle in for that issue while still under warranty and want it repaired. Make certain you speak to the Service Manager, General Manager and even the owner of the dealership before you give up on them. If they refuse, try another dealer and bring in your documentation that your issue started before the warranty expired. Then work your way up the warranty chain of command to the regional or zone office. They owe you a repair and can get authorization for "out of warranty" repair. But only if you scream loud enough. :rolleyes:
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
