Door Replacement Speakers 6.5s?
rayy79
door speakers rattling in NBS regular cab. non bose; looks like factory seperates. crutchfield has the infinity refernce seperate components 6.5s for a 100$; is this a good replacement? will be using factory radio; no amp; the "kappa 3 way is about same price. do i need to stay with components? also is it worth replacing/upgrading rear speakers; which look like 4x6s right behind headreast on regular cab? thanks; any advice/info greatly apprecciated. Ray
I went with the Infinity's listed here and they were $100. I like them so far, they sound better than the the factory and you can control the db output on them by 3 with a push button on the speaker.
The 3-way Kappa's I see on Crutchfield are about $169.99, with the 2-way Kappa's being $129.99.
With the 3-ways I would think that you would want to amp them, if you're not going to do that then there is really no need for them. Stick either with the 2-ways (Kappa's or the one in my post).
Speaking of Kappa's, I almost bought some 4x6 Kappa's ($129.99) for the rear but went with last years model instead (Infitiy).
is no one using component speakers and utilizing the factory column speaker location?
Is that the 2-part speaker system? Does the factory column speaker location have pre-installed wiring?
column? you mean the tweeter location in pod panel? i would say yes if there is an existing speaker/tweeter. the component series from infinity i was speaking about are on sale at crutchfield; like regular 159; on sale for 99$; they are the reference series; which is a step below the "kappa" series. both are infinity brand. the 2 way like you spoke of is a great set too; as i had a set in 98 chevy. i am going to try the seperate infinity's this time.
