Factory Battery Gmt900
NBS GMT900
Anyone know the difference between the standard truck battery and the optional truck battery?
Anyone have the optional truck battery? If so, what are the numbers on it?
The standard battery (48-6YR) is 600 CCA,The optional H.D. battery (48-7YR) is 730 CCA.
Also the H.D. Battery is an "SEO" option...RPO code "6C5"
Thank you for responding.
This is what is on the battery:
Number 7641
CCA: 615
Capacity (I think as printing is very small): 70Ah
Load Test: 308
and: 48-6YR
My question to anyone who can answer this is: Do I have the standard battery or optional battery?
Thank you.
You have the standard battery.
The GM order guide says the standard battery is 600 CCA,but mine is like yours and is 615 CCA. Obviously a mistake in the book.
When I ordered my truck I tried ordering the H.D. 730 CCA battery but it was on restriction,So I couldn't get it. :(:thumbs::sigh:
"When I ordered my truck I tried ordering the H.D. 730 CCA battery but it was on restriction,So I couldn't get it."
Well, that is interesting. I ordered and paid for the 730 battery. Now what?
I was just about to accuse some 'sneaky' activities at the dealership.
unit,Check your RPO codes for "6C5",As I said before thats the code for the HD battery.
If you want I can also run a build sheet on your truck.I just need the VIN.You can post it here or PM me with it and your e-mail address.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
