cchupek Posted December 2, 2007 Posted December 2, 2007 At what point do you guys with an Edge programmer change the programming to the "TOWING" mode? I was wondering at what point the towing weight makes enough difference to need the different program. Thanks.
Ranger Posted December 3, 2007 Posted December 3, 2007 When you feel that the motor is working a little harder to pull something, then change the programming. There's no set weight. My truck pulls just fine though, I just towed my buddy's 96 Z-28 Camaro a couple days ago about 35 miles and my 5.3L didn't have much problem with it...First time I ever towed a vehicle though (on a trailer, I've flat towed several times) so I don't have much comparison.
VMax2007 Posted December 3, 2007 Posted December 3, 2007 What do you tow? With my 3000-3500 lb boat/gear, using the Towing tune along with Tow/Haul was WAY overkill. I just got my Edge in Sept, so I haven't towed much with it yet since my boat is now in hibernation. But it seems for me the best bet is to either use the Tow tune without tow/haul mode on or use the Economy tune with 91 octane and Tow/Haul. I will do more experimenting next spring to figure out the best combination.
cchupek Posted December 6, 2007 Author Posted December 6, 2007 What do you tow? With my 3000-3500 lb boat/gear, using the Towing tune along with Tow/Haul was WAY overkill. I just got my Edge in Sept, so I haven't towed much with it yet since my boat is now in hibernation. But it seems for me the best bet is to either use the Tow tune without tow/haul mode on or use the Economy tune with 91 octane and Tow/Haul. I will do more experimenting next spring to figure out the best combination. Will be picking up a new 21' bass boat in a few weeks and will be pulling it about 275 miles home from dealer. I have not had to tow much weight at all since adding the programmer, so I was wondering what others here are doing with the settings and the Tow/Haul modes.
