Drafty Foot Well
I have a 2001 GMC Yukon XL 1500 and there is a mean cold draft in the passenger's foot well (only when it's cold out, obviously). I have posted on here before but I haven't gotten much response... I can't imagine I'm the first person to come across this problem, does anyone have a better solution than shoving a rag up there to try and stop the draft (that's what I've done so far, and it doesn't work very well).
Thanks in advance for any useful advice....
My pick up has a draft as well in the foot well. To stop it I just reach down and push the lever in on the vent in the kick panel. Oh, that is on my 1971 Chev Pick up. :crackup: Thing used to be simple.
Seriously, I have an 02 Yukon XL as well and there is no draft in either footwell.
I would agree with the other post, if it is coming from the heater vent duct, you have a mixing door that is not closing properly. If is not coming from the vent, you must have a firewall plug or boot that has been damaged or removed.
Sorry I cannot be of more help but I have never heard of this.
The cold air is coming in from the fresh air intake which needs to be there to keep the windows clear.
1st...make sure your cab filters are clean so it actually can move air, and when you reinstall the underdash shield make sure it is not blocking the vents under there.
2nd...from the point of the underdash panel from the center to the kick panel take a 12'' piece of foil insulation(thin and easy to work with) and put it behind the panel and up in behind the glovebox area and get it all up as hi as it will go and then grad some 2'' foam and fill in the area at the kick panel.
This will force the cold air back up into/behind the dash so it warms up before coming back into the cab.
3rd...for extreme people with cold feet...remove the lower dash vent on the driner side and plug the last hole in the vent with a rag.
This is a guaranteed fix if done properly.
I had a 2001 Tahoe that had a similar condition. It was covered in a TSB. A lot of the SUVs and trucks from around that time had the same problem. I did a search and managed to find the verbiage for the TSB, but not the TSB number itself.
Here is the TSB.
Passenger Side of Vehicle Colder/Warmer Than Drivers Side (Repair HVAC Case to Cowl Seal) #01-01-37-008
Passenger Side of Vehicle Colder/Warmer Than Driver's Side (Repair HVAC Case to Cowl Seal)
1999-2001 Chevrolet and GMC C/K Pickup (Silverado, Sierra) and Utility (Suburban, Tahoe, Yukon, Yukon XL) Models
2002 Cadillac Escalade
Condition
Some customers may comment that the passenger side of the vehicle may be:
Colder than the driver's side when the heat mode is on.
Warmer than the driver's side when the air conditioning (A/C) mode is on.
There may be dampness on the vehicle dash assembly when the A/C mode is on.
Cause
Condition may be due to poor sealing of the HVAC air inlet case to the front of dash or the recirculation mode door actuator may not hold the recirculation door closed while driving.
Correction
Replace the recirculation door actuator (if necessary) and repair the HVAC case to cowl seal using the following procedures:
Place the A/C control in the manual heat mode.
Remove the fixed mast radio antenna.
Open the hood and install fender covers.
Remove both wiper arm assemblies using the following procedure:
Disconnect the washer solvent hose from the air inlet grille panel nozzle.
Remove the cover from the wiper arm retainer. Remove the retainer.
Important
Use a battery terminal puller in order to remove the wiper arm.
Rock the wiper arm back and forth in order to loosen the arm from the drive shaft. Remove the wiper arm.
Lower the hood.
Remove the air inlet grille panel using the following procedure:
On each end of the air inlet grille panel is a rubber flap for the hood hinge cutout. Lift this flap and remove the air inlet grille panel attaching screw.
Remove the air inlet grille panel center top push pin.
Remove the clips that position the forward edge of the grille panel to the top of the cowl.
Disconnect the windshield washer supply hose from the bottom of the grille panel.
Remove the air inlet grille panel by sliding the panel rearward up the windshield and out.
Just to the left of the right hood hinge, on the horizontal surface of the cowl, locate a cover that is sealed in place. The cover has TRW stamped into it.
With a sharp knife, cut out the panel following the panel impression in the sealer tape.
Place a lifting device between the cover and the dash. Lift the cover enough to allow another tool to depress and release the front retaining tabs by pushing rearward on them. Remove the cover.
Look through the opening where you just removed the cover. You will see what looks like a piece of foam about 76 x 127 mm (3 x 5 in). This is the A/C recirculation door that is within the HVAC module.
Reach into the opening and carefully pull on the air inlet recirculation door. If the recirculation door moves with very little effort, replace the air inlet (recirculation) door actuator (Manual systems only). For systems with the Automatic Temperature control, initialize the system using published Service procedures.
Between the top of the HVAC air inlet module (appears as a 6 mm (1/4 inch) black strip) and the cowl sheet metal is a foam seal. This foam seal may be improperly positioned or damaged in some way (insufficient crush/sealing). This may allow outside ambient air to enter the passenger compartment incorrectly (under driving conditions). This can be corrected using the following procedure:
Important
It is imperative that a good seal be achieved over the entire surface areas (no voids or skips), especially around the rear and sides of the HVAC case to cowl areas.
Seal the area between the cowl and HVAC case with RTV Silicone Rubber Sealant, P/N 12345739 (in Canada, use P/N 10953541).
Using your finger, from the engine side of the cowl, ensure that the foam is stuck nicely to the HVAC module and does not have any distortions.
From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, place a shop cloth into the opening and cover the blower fan. This keeps silicone from dripping onto the motor and causing an imbalance condition.
From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, apply the RTV silicone to bridge the gap and cover the foam between the cowl sheet metal and the HVAC module case. Inspect your work with a light and a mirror. Ensure that no gaps or skips are present in the RTV seal.
Inspect your work for potential drips, runs, etc. If no problem is seen, remove the shop cloth covering the blower motor.
Apply a 3 mm (1/8 in) bead of weatherstrip adhesive, P/N 12345097 (in Canada, use P/N 10953479) around the opening in the horizontal surface of the cowl, where the cover fits into the cowl.
Place the cover on the workbench, top on the surface, and apply a 3 mm (1/8 in) bead of weatherstrip adhesive on the edge of the cover.
Place the cover into the cowl opening and snap into place.
Apply another bead of weatherstrip adhesive around the joint between the cover and the top of the cowl. Smooth this bead into a smooth surface with a finger or tool of some kind.
Place the leaf screen to the cowl. Attach the washer supply hose to the bottom of the air inlet grille panel. Do not place the fasteners in at this time.
Install the radio fixed mast antenna. Tighten 1/4 turn after contact is made with the base.
Lower but do not close the hood.
Center the opening in the air inlet grille panel around the antenna mast and then install the air inlet grille panel retaining screws. Tighten
Tighten the screws to 2 N·m (18 lb in).
Raise the hood.
Reinstall the air inlet grille panel center retainer and front edge retaining clips.
Cycle the wipers to ensure the wiper system is in the parked position.
Important
Inspect the windshield lower edge on each side. About 51-76 mm (2-3 in) from the bottom, you will find a 13 mm (1/2 in) long black mark embedded in the glass. The black line is the position for the wiper blade to be in when the wiper system is in the parked position.
Install the wiper arm assemblies. Position the wiper blades just below the black marks in the windshield.
Install the retaining nuts. Tighten
Tighten the retainers to 25 N·m (18 lb ft).
Reconnect the washer hoses.
Remove the fender covers.
Close the hood.
Parts Information
Part Number Description
12345097 (In Canada use P/N 10953479) Adhesive, Weatherstrip
12345739 (In Canada use P/N 10953541) Sealant, RTV Silicone
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
D2118 Seal, HVAC Module to Body 1.3 hrs
Add Actuator, Air Inlet Door - Replace 1.0 hr
This is a unique labor operation for use only with this bulletin. The number will not be published in the Labor Time Guide.
© Copyright General Motors Corporation. All Rights Reserved.
Hope this helps.
Phil
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,113 Guests (See full list)
