Climate Control Problems
peggin
hi guys,
i have been a lurker for quite some time and love the site. i have learned quite a bit and have a little mechanical experience. this is my first post, so bear with me and i will be very thankful for any help at all.
i have an 2004 silverado with temp. control problems and it is getting very cold here. the temp. control has been "sticking" on me today, thankfully it is stuck on hot (or red). when the problem started out i could just change from hot to cold rapidly and it would finally do what it was told, now it has a mind of its own. keep in mind this is running no ac, no recirculate, and it doesn't matter the fan speed or the direction the air is moving. the only problem is the temp won't change most of the time. the factory warranty just ran out so i would like to save a few bucks if this would be an easy swap.
thanks alot!
Doesnt it have auto a/c or manual a/c????
is it happening only on the driverside or only the passenger side???
its probably a air mix actuator sticking... the actuator for the driverside temp control is an easy job, the one for the pass. side is time consuming....
most likely it is only the driversside, the passenger side is probably working fine you just havent paid attention...
thanks for the response, it has the button with the snow flake on it and you have to push it to get the ac to come on.... so i guess that would be manual ac? im not sure the difference between manual and auto ac. today it was only on the driver's side for sure, and after turning the truck off and then back on with a quick flick of the climate control it started working again.
hope this helps, and more input would be greatly appriciated (sp)
thanks
just found some new info on recalibrating the air mix actuator. if this sound like a good idea for my problem please chime in or give me your opinion.
1. remove key
2. disconnect negitive battery cable and touch it to the positve
3. reconnect
4. put key in and turn key on/engine off for a minimum of 40 sec.
5. turn key off
6. turn engine on
thanks, peggin :D
yes, you shoudld do that first...recalibrating the actuators fixes concerns like yours alot of the time.... from what you explained, it sounds like that may fix it... but if it doesnt, then you need to replace the actuator...
for those of you that are keeping up with this post, the temp control on the driver's side finally stuck for me so i could take it to the dealer with the problem in hand. they hooked it up to the computer and found a loose wire connection in the compartment on the side of the glove box. they pulled the plastic triangular piece off that is right up against the passenger door and found one of the adaptors (that has several wires pluged into it) had "shaken loose," plugged it back in and it worked perfect!!!
THE BEST PART........ 36726 MILES AND NO CHARGE!!!!!! :lol:
I wouldn't be surpised if it doesn't act up again very common problem. I have fixed them with repairing the loose wires on the pass side of the dash behind the panel, but they always came back on me cuz the actuator binds. What I'm trying to say if it acts up again replace the temp actuator for the affected side. good luck
so the actuator binding is very common??? and when it binds it loosens the wires behind the panel on the passengers side?? i don't quite understand. please expain further if you will, and thanks for the response! :thumbs:
The actuator is a butterfly style heater door control, the 03-04's can overtravel the set opening and closing limits on the circuit board, which can cause the heater door to stick closed. In the case above, the wires controlling the actuator came loose making the hold the same temp all time. More commonly the actuator sticks and needs to be replaced, about $100 for the part.
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
