V.i.n. Check?
I've seen some guys here volunteer to run a VIN check for members here but rather than hijack someone elses thred I thought I would post it here. I just bought this truck 11 days ago with 34,6xx miles on it and it came GM Certified. It only shows that it was serviced and washed but I found a receipt in the glove box for an intermediate steering shaft replacement. I'm wondering what else I may find about it. So if someone would please enlighten me I would be very thankful. The VIN is 2GCEK13T251238441 . I would be interested in anything I could find out about it including installed options and any work ever performed. Thanks in advance.
Yeah I will check it and post as soon as I can get logged onto Dealer World (unless Rich beats me to it)
Good looking truck.
build date 12-15-04
sold and delivered 3-31-05 to 1st owner
only one warranty claim-steering shaft replaced 9-22-06
clean bill of health.
I guess I'm paranoid because the smell of burn't popcorn shows up after heater has been on hi for 10 minutes, and because sometimes when I push the defrost button when it's on just to turn it off the entire system shuts off and other times when I do the same thing it cycles to the heater and does not shut the system down completely. I'm guessing this should be consistant and predictable and not something of it's own choice, but then maybe I'm wrong.
Here ya' go......
GM Vehicle Inquiry System
VIN : 2GCEK13T251238441
VEHICLE INFORMATION
Merchandising Model : CK15543 -2005 SILVERADO 1500 4WD CREW CAB LT
Warranty Start Date : 03/31/2005
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
AL SERRA CHEVROLET, INC.
PO BOX 877
GRAND BLANC , MI 48480-0877
(810) 694-5440
Selling Source : 13 - CHEVROLET
Site Code : 44007
Business Associate Code : 115178
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS :
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS :
ONSTAR HARDWARE IS DIGITAL-CAPABLE. NO UPGRADE IS NEEDED. SEE TSB 06-08-46-008.
ON STAR AND XM SATELLITE RADIO INFORMATION :
OnStar Equipped-Yes OnStar Status-Inactive
Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped-Yes XM Radio ID#REW8804P XM Status-Active
Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES :
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/31/2005 43 miles 03/31/2008 36043 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/31/2005 43 miles 03/31/2011 100043 miles
39/39000 GM CERTIFIED USED LIMITED WARRANTY 03/31/2005 43 miles 06/30/2008 39043 miles
60/100000 GM CERTIFIED USED POWERTRAIN LIMITED WARRANTY 03/31/2005 43 miles 03/31/2010 100043 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/31/2005 43 miles 03/31/2013 80043 miles
36/36000 FEDERAL EMISSION 03/31/2005 43 miles 03/31/2008 36043 miles
CLAIM HISTORY :
R.O Date R.O Number Type Labor Operation Odometer Reading
09/18/2006 043946 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 16175 miles
12/15/2004 A38441 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 09/18/2006
Repair Order Number : 043946
Odometer Reading : 16175 miles
Serviced By :
TODD WENZEL CHEVROLET
PO BOX 310
HUDSONVILLE, MI 49426-0310
(616) 669-6683
Site Code : 44026
Business Associate Code : 206255
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
09/22/2006 728 01 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 26098419 - LUBE KIT N
Repair Order Date : 12/15/2004
Repair Order Number : A38441
Odometer Reading : 0 miles
Serviced By :
PO BOX 877
GRAND BLANC, MI 48480-0877
(810) 694-5440
Site Code : 44007
12/21/2004 545 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
VIN 2GCEK13T251238441
VEHICLE BUILD
Gross Vehicle Weight Rating : 3178 kg (7007 lb) Order Number : HTFN18
Build Date : 12/15/2004 Build Plant : 25143
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT
AG2 - 10-WAY POWER PASSENGER SEAT
AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
AM7 - FOLDING REAR SEAT
AN3 - FULL FEATURE BUCKET SEATS
AU0 - KEYLESS REMOTE DOOR LOCK
AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS
B30 - CARPETING, COLOR-KEYED
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
CJ2 - AIR COND., DUAL ZONE AUTOMATIC
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5W - 7000 LBS GVW RATING
DF5 - ISRV MIRROR W/COMPASS & TEMP
DK7 - INTERIOR CUSTOM ROOF CONSOLE W/ MAP LIGHTS
DL3 - OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL
DT4 - ASHTRAY MUFFIN
D07 - CUSTOM FRONT FLOOR CONSOLE
EVA - EVAP EMISSION REQUIREMENT
E63 - FLEETSIDE BODY
FE9 - 50-STATE EMISSIONS
FF6 - TORSION BAR SPRING ADJ. - LH
FF7 - TORSION BAR SPRING ADJ. - RH
GU6 - REAR AXLE 3.42 RATIO
G80 - LOCKING REAR DIFFERENTIAL
JF3 - BRAKE VAC POWER
JJG - FRT END SUBASSEMBLY
KG3 - 145 AMP ALTERNATOR
KNP - HD AUX TRANS. COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC
K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER
LM7 - VORTEC 5.3L 295HP IRON BLK V8
M30 - 4-SPD AUTOMATIC TRANSMISSION
NP5 - LEATHER WRAPPED STEERING WHEEL
NP8 - AUTOTRAC ACTIVE TRANSFER CASE
NT8 - EMISSION SYSTEM FEDERAL, TIER
OSG - OSHAWA ASSEMBLY PLANT
PDB - SAFE & SOUND PACKAGE: * XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INC
PDU - LIGHT DUTY POWER PACKAGE: *VORTEC 5.3L 295HP IRON BLK V8 *LOCKING DIFFERENTIAL-REAR AXLE *HD TRAILERING EQUIPMENT
P25 - 17" ALUMINUM WHEELS
QJM - P265/70R17 OOR WOL TIRES
R5C - TIRE BRAND ALL BRIDGESTONE
R9Z - POMS EXPEDITE-SOLD ORDERS
SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS
SSB - IDENTIFICATION MODEL
TR3 - CHROME GRILLE
T96 - FRONT FOG LAMPS
UC6 - AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPEAKER SYSTEM
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND
UK3 - REDUNDANT RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS
UQ7 - BOSE SPEAKER SYSTEM
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
VB3 - CHROME REAR BUMPER
VG3 - CHROME FRONT BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XJM - TIRE FRONT P265/70R17-113S WOL R/PE ST TL OOR
X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - SILVERADO
YJM - P265/70R17-113S WOL R/PE ST TL OOR
ZJP - SPARE TIRE P265/70R17
ZY1 - SOLID PAINT
Z82 - HD TRAILERING EQUIPMENT
Z85 - HEAVY DUTY SUSPENSION
1SC - LT DECOR INCLUDES: * OSRV MIRRORS W/ DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ. HEAT, TILT & TURN SIGNAL * AUTOMATIC A/C * FRONT BUCKETS WITH PWR ADJ. * REAR WINDOW DEFOGGER * DEEP TINT GLASS * AUTOTRAC TRANSFER CASE * FRONT FOG LAMPS * AM/FM STEREO W/ 6-DISC CD CHANGER & BOSE SPEAKER SYS * ALUMINUM WHEELS * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * ISRV MIRROR W/COMPASS & TEMP * LEATHER WRAPPED STEERING WHL * BODY SIDE MOLDINGS * ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND * REDUNDANT RADIO CONTROLS
1SZ - TOTAL POWER PAC SAVINGS
6YT - COMPONENT FRT LH COMPUTER SEL
69I - DK PEWTER INTERIOR TRIM
692 - DARK CHARCOAL LEATHER SEATING SURFACES
7YT - FRONT SPRING
74U - VICTORY RED
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 03/31/2005
Delivery Type : 032 - GMS EMPLOYEE OUT-OF-STOCK/OPT 2 LEASE
Delivered Odometer : 43 miles
Delivering Dealer :
PO BOX 877
(810) 694-5440
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 44007
Rich, Thank you Very Much. I will attempt to print this off for future needs. I really love this truck and want to know everything about it I can find. I intend to keep it for a very long time and the more I know about it, the better I feel about it.
By the way,They didn't replace the steering shaft,all they did was lube it.
Part#26098419 is for the lube kit,not the shaft,which is part#19153614.
Thanks Rich, I was going by this receipt I found in the glove box.
Autocheck shows it was a lease vehicle. but everything else checks out ok. For a copy of the report pm me your email and I will send you a copy.
I want to thank everyone for their efforts, You have been very helpful and I do appreciate all the efforts. Thanks again. Bob.
that is funny because i live less than a mile away from where that truck was first leased in grand blanc mi. I love the guys there and i have bought a few vehicles from them. RVJ do you live in Nebraska currently?
Hi Clinton, Yes I live in a little suburb of Lincoln on the west side called Emerald.
  • 1 month later...
