6.2 L Gmc Denali Check Engine Light
I HAVE A NEW 6.2 L GMC DENALI AWD (2008). RUNS FINE. WHEN I USE THE REMOTE START, THE TRUCK WILL RUN FOR A MINUTE OR LESS AND THEN SHUT OFF. THE CHECK ENGINE LIGHT COMES ON. I CAN START THE TRUCK AND IT WILL RUN OK, BUT THE CHECK ENGINE LIGHT STAYS ON AND I CAN'T USE THE REMOTE START. I TOOK IT TO THE GMC DEALERSHIP AND THEY SAID THE LIGHT WAS CAUSED BY AN EMISSIONS PROBLEM AND RESET IT. THEY SAID THERE IS A SPECIAL FIRING SEQUENCE WHEN THE REMOTE START IS USED TO MAKE THE TRUCK HEAT UP FASTER. I JUST HAD THE SAME THING HAPPEN AGIAN. ANYONE ELSE HAD THIS PROBLEM OR ANY IDEAS WHAT IT COULD BE? THANKS FOR ANY IDEAS. I'M TAKING IT IN AGAIN TOMMORROW AND I WILL POST AN UPDATE.
I have not experience this issue with mine. Let us know what they come up with for a solution.
Just saw this thread. I hope your problem went away, but if not try this: disconnect the negative battery terminal for at least 30 minutes. I was having a similar problem and this cleared it up. It's amazing what resetting everything will do.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
