Rattling Sound
in motion? pressing the gas? over bumps? reason why I ask is because my power steering pulley came out of alignment, which in turn messed up my belt and my dealership just finished replacing it (took them 2 hours because I had an appointment and it was diagnosed before the service visit), under what conditions does it appear?
body bushing? washer gone bad? mine did...here is my GMVIS history for the description:
11/13/2007 060298 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 22151 miles
11/13/2007 060298 # R0942 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 22151 miles
11/13/2007 060298 # E8041 - TIE ROD, INNER - LEFT - REPLACE 22151 miles
11/13/2007 060298 # R0760 - RADIO, REMOVE AND REPLACE 22151 miles
11/13/2007 060298 # D4450 - A/C SYSTEM - ANALYZE 22151 miles
11/13/2007 060298 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 22151 miles
11/13/2007 060298 # R0950 - RADIO REAR SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 22151 miles
11/13/2007 060298 # R0943 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - LEFT SIDE 22151 miles
11/13/2007 060298 # R0951 - RADIO REAR SIDE DOOR SPEAKER REPLACEMENT - LEFT SIDE 22151 miles
11/13/2007 060298 # E1730 - CROSSMEMBER, FRONT SUSPENSION - REPLACE 22151 miles
I have a rattling sound coming from the right front area when it s very cold outside. Seems only when moving slowly also. Any one else find this ??
i got that too! just noticed past few days. to me it just sounds like rubbin plastic near the right side heat vent. i punch the dash near it and seems to away?
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
