Factory Wheel Torque Spec.
I looked in my manual for the torque specs for the factory steel wheel and could not find any. Does any one know the torque for that wheel?
IIRC 140ftlbs
Thank you very much. I just bought a 100 LB torque stick for the wife's SUV. Do you think that will be adequate to use or will it be to light?
IIRC 140ftlbs
Torque Sticks are designed for use with an impact wrench, and not all that accurate. Besides, there's a big difference between 100 lb-ft and 140 lb-ft. 100 lb-ft is not enough torque.
IIRC 140ftlbs
Yes, I bought the torque for my 1/2" air impact gun. I guess I'll just use it like I have been, with out the torque stick then. I am to cheap to buy another stick for 140 LB for $50.00.
I would not use a torque stick or an impact on my wheels. I always use a torque wrench on lugs, torqueing to 1/2 value in pattern, then at full value, again in pattern.
Husky 250Lb wrench for $80.00? I got mine for $37.00 6 months ago, must be in high demand if the price has gone up that much.
IIRC 140ftlbs
Yeah I made the mistake of spending $50.00 on a 100 lb on from my Snap-On guy then when I needed another one I went to Harbor Freight and got a set of 8 torque sticks with different torque ratings for $80.00
IIRC 140ftlbs
Thats a good price.
I would not use a torque stick or an impact on my wheels. I always use a torque wrench on lugs, torquing to 1/2 value in pattern, then at full value, again in pattern.
That is what torque stick is designed for. Also no one ever sees the lugs on a factory wheel because they are covered by the center cap.
Do yourself and your truck a favour. Buy a moderately priced torque wrench, as in not the Chinese $24.95 specials, and tighten the lug nuts properly. Dress the mounting surfaces with a wire brush or Roloc "finger" disk if needed. Hand tight, just snug, then patterned in two or three stages. #1 cause of brake vibration is improper wheel nut procedures.
If you buy a Torque-stick set and are willing to take the time to use them properly, then by all means. I've never, in all my years working in truck shops and observing tire shops, seen any one install a wheel properly with them. Human nature, being what it is, the mechanic will ultimately take short-cuts. And it's monkey-see, monkey-do when the young apprentices learn their trade. How many times I've had to get out the breaker bar and 3' extension to loosen wheel nuts after a flat repair...
Lugs on my '07 are not covered by the center cap. Besides, what does that have to do with torqueing the lugs?
I thought that you were worried about the impact beating up the surface of your lug nuts. I did not know yours were exposed. On the steel wheels they are hidden by the center cap.
the lug nuts should be covered on the premium wheels also by a small plate and lug nut cover screws. At least it is on my dads Tahoe.
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   4 Members, 0 Anonymous, 480 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
