2007 Tahoe Dvd Radio Output Question.
Wife has a 2007 Tahoe with the factory DVD radio (flip down screen in back, DVD is loaded into the head unit). I'm thinking about replacing it with an aftermarket DVD navigation radio but am wondering about the outputs to the rear flip down DVD player. What kind of output is there from the radio? RCA or something else?
Good luck Paul. I have been posting questions about the schematic/pin map to try and figure which pins on the factory radio are the video out, so I can add screens to my factory head unit. These radios are too new still, no one has figured out the answers yet.
