Dvd Player On The Fritz
The flip down DVD player is glitching. Looks like its the ribbon cable which is an easy enough fix. Is it worth fixing or should I just go aftermarket? Is this a common problem or is it fine once you repair it once?
it would probably be better to go aftermarket because of the cost that could be involved with the repair. Is it just the ribbon? or is something else out of whack and by the way what is your OEM screen size?
