Rancho Quick Lift
I asked about this a couple of months ago and the members of this forum said that it is only for the GMT-900 platform. Which after doing more research, is pretty logical.
  • 10 months later...
sorry to bring this back from the dead, but I have an 08 Sierra Crew Cab, looking at doing some 20"s with 33's in a few months. Anyone have this kit on their 07-08, if so how do you like it? Does the lift ride rough? I dont do a lot of off-roading but do have some crazy winters(for the stock wheels of course), But I would like to level the truck out and put some nice 20" rims and tires on. I am going to put Nitto Terra Graplers, or a tire of that sort on them as well.
thanks for the input
