Mod Advice Please.
Im looking at performing some mods to my newly aquired '00. On the list are headers, MSD 6A Ignition, and a programmer. Which brands of the above should I look into? . . Im in college so cheap deals are better than top performance. also mostly looking for fuel economy. I already have a K&N Intake system and MSD wiring. . . In a rush out the door so I'll probably embellish when I get back from dinner.
Thanks
I, like everyone else on here will tell you to get a custom tune rather than a programmer.
wait4me, westers are good brands.
As far as the other stuff, Im in the same situation. Id like to get some power mod info for my 2000 Sierra.
So far, Gibson headers have been about the cheapest ($300-$400) but I hear headers wont give large gains so I havent gotten them yet.
Really . . .how much do those custom tunes run and how would I go about it? . .
I was just looking into some pacesetter shortys (running ~$240 shipped on Ebay) as it is the last part of my exhaust I have to change. . . . are there any differences in sound with shortys?
I think the MSD Ignition would be good for gas and is also $200 . . . Never heard that much about ignition systems but I always wanted one :D . . This is my first truc that I have had that I can be that far down the mod list with. (Father pre-modded everything else I want :))
Ill be posting soon (maybe tomorrow If I can get it washed) in the new members thread with a more comprehensive lists of mods done.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
