Vin Details Needed
I currently have a 1989 Chevrolet K1500 with Vin #2GCDK14H0K1156676. It has some cracks in the front differential housing and is leaking fluid. I'm not sure what gear ratio came with this truck due to the options sticker not being legible. I also have a 1991 chevrolet with VIN #2GCEK14Z0M1103122 as a parts truck, which the options sticker isn't available either. Can any one help me to see if the gear ratios are the same and whether or not the front differentials are interchangeable? Any options which are obtainable via the VIN#s would be appreciated.
The VIN by itself won't give you any options outside of the motor, but you might be able to take the VIN to a Chevy dealer and ask the service department to run the VIN to find out what was on it. If you ask nice, they might even print out the listing for you.
Well,The '89 is too old for me to run.
But I was able to run the '91,It has 3.73 gears and no "G80" locking-differential.
It also has the "F44" heavy-duty chassis package,heavy-duty shocks,engine oil cooling system and heavy duty radiator and transmission cooler.
Thanks for the info. Can you give me a complete list of all of the codes for the 91, VIN #2GCEK14Z0M1103122 ?
Sure,But let me get back to you....I want to run both VIN's on our "in-house" parts catalog system at the dealership,I'll list all the RPO codes once I run them,I'm hoping maybe the '89 will come up....but I'm not holding my breath,usually '90/'91 is the oldest we can get codes for.
I have to list all the codes manually,I can't "copy & paste" from our in-house system.
OK,The '89 won't come up with the RPO codes,You'll have to look on the rear axle housing itself for possibly a code or casting numbers (Should be on the front of the right axle tube,3" to 5" outboard of the carrier)
Heres the RPO codes for the '91....
MODEL : CK10903
BUILD DATE : 08/17/90
A28-SLIDING REAR WINDOW
A52-SEAT,FRONT BENCH,3-PASSENGER
BZY-LINER PUBX,BEDLINER
C5M-GVW RATING, 6100 LBS. GVWR
D44-MIRROR,OUTSIDE,BELOW EYELINE PAINTED
E63-BODY EQUIPMENT,FLEETSIDE PICKUP BOX
FK2-ARM,TORSION BAR,SPRING ADJUST,LH
FK3-ARM,TORSION BAR,SPRING ADJUST,RH
F44-CHASSIS EQUIPMENT,HEAVY DUTY,HVY DUTY CHASSIS
F51-ABSORBER,HEAVY DUTY SHOCK
GT4-AXLE,REAR,3.73 RATIO
JB5-BRAKE SYSTEM,VACUUM POWER DISC,DRUM
KC4-COOLING SYSTEM,ENGINE OIL,ENG OIL CLG.
K99-GENERATOR,85 AMP
LB4-ENGINE,4.3-V6,EFI,4.3Z
MD8-TRANSMISSION,AUTOMATIC 4-SPEED (THM700R4/4L60)
MX0-TRANSMISSION,AUTOMATIC,OVERDRIVE (MERCHANDISING OPTION)
NA1-EMISSION SYSTEM,LESS THAN 8500 LB GVWR
NA5-EMISSION SYSTEM,FEDERAL REQUIREMENTS
OSG-PLANT CODE,OSHAWA,ONT,GM OF CANADA,OSHAWA TRUCK PLANT
P01-COVER,DELUXE WHEEL TRIM
R8T-N/A
SLM-STOCK ORDERS
UL5-RADIO DELETE
VK3-LICENSE PLATE,FRONT MOUNTING PACKAGE
VLA-WORK TRUCK PACKAGE
VXS-COMPLETE VEHICLE LABEL
V02-RADIATOR,HEAVY DUTY,INCLUDES HEAVY DUTY TRANSMISSION OIL COOLER
V43-BUMPER,REAR STEP,PAINTED
V73-VEHICLE STATEMENT-US/CANADA
XHE-TIRE FRONT LT225/75R16/C BL R/PE ST ALS
X88-CONVERSION CHEVROLET,CHEVROLET NAMEPLATE
YD3-AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD6-SPRING,REAR (BASE EQUIP)
YHE-TIRE REAR LT225/75R16/C BL R/PE ST ALS
ZHE-TIRE SPARE LT225/75R16/C BL R/PE ST ALS
ZY1-COLOR COMBINATION SOLID,SOLID PAINT COMBO
1SB-PACKAGE-OPTION 02
47C-TRIM COMBINATION CLOTH,DK RED
47I-INTERIOR TRIM,DARK RED
6GF-SPRING COMPTR SELECT FRT LH,SUSP
7FG-SPRING COMPTR SELECT FRT RH,SUSP
96U-EXTERIOR COLOR,PRIMARY
96U-PRIMARY COLOR-EXTERIOR,DK SMOKE GRAY MET.
Ok Thank you for the codes. Both trucks are 4 wheel drive but I don'e see any reference to the front end ratios. Are both the front and the rear the same ratio? I know it seems like a silly question but even in the chilton's manual I can't find any reference. I was able to make out the rear end code as a GT4 3.73 on the 89 so if both trucks have the same rear should it be safe to assume that both have the same front ends? Again thanks. The 89 has some sentimental value to it and in hope of doing a complete rebuild in the future. Is there anyplace to find a code clarification for the rear end code?
Yes,3.73's will be in both the front and rear (If not you're in BIG trouble!!!)
