Regular Cab 2007 Nbs Question
I am thinking of buying a left over 2007 GMC sierra 2500HD regular cab 4X4. Just wondering if anyone has towed a 30' 6000# travel trailer with one of these and the 3:73 rear end? I had towed with a 2000 2500 crew cab and the 350 vortex with 3:73's. The 2000 did OK, but you had to plan your passing and hillclimbing very carefully. I also had a 2002 GMC sierra 2500HD 6.0 crew cab for two years and that had 4:10's and did only slightly better than the 2000. I guess I am wondering if the 6-speed gearing will help things with the 3:73's.
Aside from towing, what type of general fuel mileage should I expect with 70% Highway and 30% City?
Thanks
Tim
I hope it is a diesel. Practically, there is NOT a 30 ft trailer that weighs 6K, in reality, though the trailer specs do thier best to be deceptive. That is what the framework weighs.
No diesel, just the 6.0
I am just guessing at the 6000#, Its a 30' Jayco with no slide out. The tag on the camper says 4995# and I figured with all our stuff, propane, water, ect. it would be at least 6000#.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
