2000 Silverado Radio
I have a 2000 Silverado. Several of the buttons no longer lightup and the CD player makes some strange noises. I plan to replace the radio with a factory replacement and would prefer to upgrade to a radio with a MP3 input. Does anyone know if such a radio exists?
No factory 1995-2002 radio will play MP3s, but P.I.E. manufactures an adapter that converts the external cassette/CD player input into an auxiliary input.
Thanks for posting that link .
I've been looking to replace the stock radio/cd in my '02 but after seeing those prices I might just get something aftermarket instead .
Very good link .
Personally I like aftermarket stuff better. They will put more power to your speakers and most come with the option of a remote control which is nice to have if you don't have steering wheel controls..
I agree. If you don't mind having something in your dash that doesn't look factory, you'll be much happier with an aftermarket head unit.
Thank you for all the great feedback. I've considered aftermarket, and the feedback indicates that is the best way. Thanks to all who responded
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
