Wheel And Tires Coming Soon!
Ordered Moto Metal wheels and Nitto Terra Grapplers for my 07 Silverado w/ leveling kit. Hope they'll be here tomorrow.
I was also wondering about the 3" body lift for the NBS. What would it look like?? Anyone have pictures? From what I hear it doesn't look too good because of the undercarriage showing too much. Help me decide if y'all can.
It would look like this truck. Just get some side steps and it will hide the frame.
What size are those wheels and tires?
